Fast Idle Control
nht mike
Is there a way I can use my cruise control for fast idle while the truck is stopped? The truck is an '11 NHT 4X2.
Thanks
Mike
No
Why would you want to?
Hello! In my owners manual it talks about using the cruise for fast idle (1200 RPM) if you have that option. When I'm pulling my trailer and we stop for any reason I like to run the engine at about 1000 RPM no load for a minute or two to let things even out before shut down.
I stand corrected...
If you follow the instructions and it works then you have it. If it doesn't work then you don't have that feature.
Fast Idle System
If the vehicle has this feature it is
available only with cruise control.
The manual fast idle switch is
operated using the cruise control
buttons located on the left hand
side of the steering wheel.
This system can be used to
increase engine idle speed
whenever the following conditions
are met:
. The park brake is set.
. The brake pedal is not pressed.
. The vehicle must not be moving
and the accelerator must not be
pressed.
To control the fast idle:
. To enable the Fast Idle System,
press and release the Cruise
Control On/Off button and
ensure that the switch LED is lit.
. Press and release the Cruise
Control Set switch. Engine
speed will be held at
approximately 1200 RPM.
When the fast idle is active the
Driver Information Center (DIC) will
display “FAST IDLE ON.”
One of the following actions will turn
off the fast idle:
. Pressing the brake.
. Selecting the Cruise Control
Cancel button.
. Releasing the Parking Brake.
. The transmission shifter is
moved out of P (Park) or
N (Neutral).
On/Off button when it was
previously on.
. Pressing the Cruise Control Set
switch a second time.
. Pressing the accelerator greater
than a quarter of the down.
. Turning the ignition switch to the
LOCK/OFF position.
Thanks for the reply. I don't have the feature. Do you know if it has to be wired in or is it a programing issue? You could pretty much say I hate all Fords, but one feature they have that I really like is a customer access wire bundle. In there are some wires marked PTO. One of them is for fast idle and the others have something to do with the transmission.
I was wondering if GM has something simular.
Mike
    Clark_Elite
    Clark_Elite
  • Who's Online   4 Members, 0 Anonymous, 353 Guests (See full list)
