Head Light Replacement?
Hey guys... I noticed the today that my passenger headlight lense is cracked. Can I replace just the lense or do I need to buy the whole assembly? I haven't check to far into it yet.. just firgured I ask.
Thanks,
Anthony
I had to remove the headlight on a customer's '09 Sierra and it wasn't too difficult. If I remember correctly, there are 4 bolts that must be removed before the assembly is liberated from the body. For a reference point, feel free to consult this 2009 GMC Sierra Headlight diagram
After you remove the bolts the headlight will pull out from the bottom :lol:
