Transfer Case Clip Issue
pm26
Must be talking about pump rub. Do the new trucks even use the same transfer case? If so then it must be fixed.
Yes, this was about the clip rubbing a hole in the outer case. So what is the answer?
Do you have more information on this pump rub? My truck has a knock when you first accelerate and I think that is the problem. Any additional info would help. THANKS
Search is your friend.
Pump rub
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 792 Guests (See full list)
