'01 1500 Suburban Fuel Pump Issues
In the past I had an '01 2500HD truck that had it's share of fuel pump problems. I had the pump replaced once at the dealer which then quit relatively quickly with a month, so back to the dealer it went. What I came to find out was that there was a Service Bulletin that detailed how the pump connector at the top of the tank would intermittently short out. Once I knew that, all it took to get the truck running again was to reach in above the tank thru the rear fender opening and unplug the pump & then plug it back in....running again. The dealer didn't even know about this until they put the second or third pump in.
Anyway...fast forward to today....I'm now driving an 01 Suburban that is now having fuel pump issues that seem very similar to what my old truck was doing. Where on the Suburban tank is the pickup and electrical connector? I'd like to try the truck trick, but can't see where it's at. As I feel the wire loom along the top of the frame rail, it seems like it branches off to the tank right where the front tank support strap is located. Is that where the pickup, fuel pump, connector, etc is located on the Sub? Is there any way to reach it without dropping the tank?
I suspect this may be the problem as there are times I hear the pump running and other times I hear nothing. I've been messing with it this evening and have replaced the fuel filter already to rule that out. I've also banged on the tank with a rubber mallet to no avail. Sometimes it runs....sometimes it doesn't.
Is the electrical plug accessible by hand?
On a side note....I'm looking on Ebay and Craigslist for new pump modules and I see some vendors selling pumps only....without the complete pump module. Is that a new offering from GM? One of the pumps I saw on Ebay was in a GM ACDelco box(red, white, blue) so it appears to be a factory part.
Second.....do Silverado trucks use the same fuel pump module as the Suburban. I found a new in box GM fuel pump module on Craigslist for a great price, but the guy says it was bought for an '03 Silverado.
Thanks in advance for any insight to these pesky fuel pump problems.
    mighty K20
    mighty K20
  • Who's Online   4 Members, 0 Anonymous, 538 Guests (See full list)
