#8 Cylinder Missfire
Carder09
Buddies truck has the #8 cylinder misfire, he says its has gotten progressively worse and will stumble upon acceleration, and he also says it developed a rattle or something of the sort. He's changed out plugs, checked wires, replaced intake gasket, and tried to do a compression test but couldn't spin it fast enough himself to check, so what could cause this. Also the codes thrown were 308 and 300 I believe.
I also forgot to mention that he swapped the coil packs, swapped injectors and is going to try a fuel pressure test though he says it runs almost as normal when driving at faster speeds
Update: he took it to the dealer and they said to him, your #8 cylinder is misfiring and you have a slight tick in the motor, funny thing is that he told them that when he got there, but they said he needs a new motor and quoted him 4000 just to remove all the components and look at the internals, not to swap the motor out completely, and not counting the cost of a new motor, so I'm not sure that may be the problem so can anyone think of somehing else that might be wrong
Weak or broken valve spring(s)? What does a vacuum gauge reading show?
How about a running compression test? There are many ways to check the internals of an engine to see if it is causing a misfire or not, you just have to know how to do them and DO them.
He is getting to that this weekend.
  • 3 weeks later...
I have a similar issue, but no codes are being thrown. :) My Aeroforce Interceptor says that I get random misfires on Cylinders 5 and 8. This happens a few times per day. But I don't notice any rough idling or weak acceleration. Could it be a bad knock sensor(s)?
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 504 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
