Center Caps
txdox21
I am considering buying a set of the GMC 17" OEM wheels due to the wider selection of tires. Where can I find chevy center caps for the wheels pictured below?
Have you seen Chevy caps on those wheels before? I know I haven't, but I'm sure you could measure the center bore diameter and hit up eBay or something. Those are nice wheels. I like them better than the OEM Chevy wheels.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
