Sierra Items
FOR SALE
2008 SIERRA TAIL LIGHTS---THESE ARE BRAND NEW AND WERE ON THE TRUCK LESS THAN A MONTH---THEY CAME OFF OF A 2008 SLE EXTENDED CAB BUT WILL FIT ANY 2007-2011 SIERRA PICK UP---$150
DENALI DOOR MOLDINGS---THESE CAME OFF OF A 2008 GMC SIERRA SLE EXTENDED CAB ALL TERRAIN---THE MOLDINGS ARE SUMMIT WHITE BUT COULD BE PAINTED---$150
LET ME KNOW ANY REASONABLE OFFERS
You wouldn't happen to have the third stop light would you?
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
