Driver's Side Rearview Mirror Housing Cracked
I accidentally caught my outside mirror on the garage door track backing out of my garage and cracked the housing. There is a small crack at the outside edge of the lip around the mirror and a small chunk taken out (See attached image). GM only services the entire mirror assembly and wants $400 for this part. Does anyone know of just the trim lip part being serviced by anyone in the aftermarket? If not, has anyone attempted to repair this piece. If I was able to use a black epoxy with something to stamp the texture back onto the surface, I could make a decent repair. Any help is appreciated!
[quote name='crunchnd' post='1210174' date='Oct 14 2011, 12:19 PM']I accidentally caught my outside mirror on the garage door track backing out of my garage and cracked the housing. There is a small crack at the outside edge of the lip around the mirror and a small chunk taken out (See attached image). GM only services the entire mirror assembly and wants $400 for this part. Does anyone know of just the trim lip part being serviced by anyone in the aftermarket? If not, has anyone attempted to repair this piece. If I was able to use a black epoxy with something to stamp the texture back onto the surface, I could make a decent repair. Any help is appreciated![/quote]
Structure effect????? If not just forget about it.....
But you could make a cast mold of the grain..... Some kind of flexible material. Then use black epoxy to fill it with then press the mold into it... make a bigger mess than it already is. But thats just my opinion.
If it doesn't effect the mirror forget about it.
Jbo
Fifty bucks brand new. No arrow so just swap your glass.
[url="http://www.autolightsbulbs.com/2007-2008-Chevy-Silverado-Mirror/K1110368.aspx"]http://www.autolightsbulbs.com/2007-2008-C...r/K1110368.aspx[/url]
