Body Work On 01 Sierra 1500
Hey guys I have a 2001 GMC Sierra 1500 extended cab, and frankly it has seen better days. The precious owner was from the northeast and anyone from there knows all too well the effects of the winter salt on a vehicle. Sadly I have procrastinated to the point that I now have holes in the rockers on both sides and was wondering if 1)how could I fix this myself. I don't mind doing the work but my knowledge of body work is nil and 2) if it is more reccomended to bring it to a shop, if anyone from the New Bern area of NC has any suggestions for shops. Thanks in advance for any replies.
you honestly dont need much knowledge to do the body work.. just buy the proper bondo and paint and you will save lots of money.. you have to wonder if its really neccesary to dump that much money for body work into and almost 12 year old truck
yeah, buy a can of color matched duplicolor paint at advance auto or pepboys or whatever is near you and paint away... i just dont understand how your truck would be rotting through only in NC and my truck has been in northeast PA for all its life
  • 4 weeks later...
cheap trick for rockers would be to clean them out as best as possible....and spray foam them with a can of 'great stuff'...let it set up...shave the excess off and apply the filler over that...not the professional way..but its waterproof and works pretty good...saves trying to get loads of filler to stay in the gap and not ooze out.
block the filler down with 80 grit to get it where you want it...buy a can of rubberized texture coat from a body supply shop..spray over the primed filler...and then spray the color over top of all of it and your done.
  • 4 weeks later...
buy a replacement rocker panel. cut the old one out, cheapest method is a grinder with a cutoff wheel. trim new panel to the size you need to replace old, and weld it in. if you don't have a mig or tig welder, you can drill holes and rivet it in. then use a small amount of bondo to fill in low spots, sand it down, and spray a little paint on it. filling the holes in with bondo only won't last to long, but will look better for a while.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
