Lift Springs
Hey guys I'm putting a 6 " rough country lift on my k1500. My rear leafs are sagging pretty good. The kit comes with a 5 " block which I think looks bad and I heard bad things with axle sealing with blocks. My question is what brand of leads out of pro comp, superlift, aor skyjacker I want a stiff spring since I have a tool bow full of tools and other stuff. Should I get real stiff 1500 springs or soft 2500s. Lastly how high can I go before I bottom my rear shocks out.
I also have Will be running dual rear shocks
from my experiance most lift springs will just give you lift, they try to set the spring rate close to stock . however you could do a lift and small block to get the stance you want, or get a 2500 spring pack and play with the blocks from there. and as for shocks go i assume youre still going to be around 6 inches of lift so it shouldnt matter
    nick54
    nick54
  • Who's Online   4 Members, 0 Anonymous, 320 Guests (See full list)
