Headlight Conversion To H4 Bulbs
lambrkt
Hi all you out there with 4 headlight 4 x 6 (165mm) systems which is most Chev/GMC 1981 - 1988 trucks, blazers, burbs and most probably 1989 - 1991 units with 150mm horizontal light systems here is some info. to save you (unlike me) a long frustrating afternoon . I purchased a conversion pair of headlights which use replaceable H4 (also is GE9003 etc.) bulbs, supposedly much cheaper than a 2A1 type sealed low beam, $9 vs $23. I wanted to leave my 1A1 high beams in place and run the conversion units as low beams since they get more use and burn out sooner. Should be 'plug and play' right? Wrong! When I connected them up, I discovered that the high beams were coming on very dim when only the lows should have been running. I am running a relay style harness from LMC and I thought the high beam relay was stuck on. Put my old wiring back; same problem. Checked the high/low beam column switch out - not the problem. Went to the store and bought an H4 bulb, disconnected both low beam units and plugged the bare bub into the three prong upper socket - problem with high beams coming on dim recreated. Clearly the H4's leak current to the high side if you use the stock wiring connections. H4's are dual filament and here is where the trouble starts.
How to fix. After some research on the internet in other forums I discovered that the stock low beam 2A1's viewed from the back, clockwise from left terminal are Ground, Low - right terminal, High - bottom terminal. H4's when viewed from the back with the top tang oriented up and the two side tangs oriented down, the way they fit into the conversion light, are Ground - left terminal, Low - top, Hi - right terminal. On my drivers' side low beam connector I interchanged the low and high beam wires. These are colored brown and green on my Burb. Problem fixed until I interchanged them on the passenger side plug. So, next I left the passenger side brown wire where I had moved it to and interchanged the black ground and the green high. Problem fixed.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
