2003 Silverado Silverado Coolent Loss
Hello im new to the sight looking for some help.. about 2 months ago i bough this 2003 silverado 1500 4wd 5.3l 105,000 miles and im haveing coolant loss issues. its going threw about a half gallon every week to 2 weeks depending on highway driving. thiers no visable leak already replaced the water pump due to pully snaping of the pump. hopeing that would fix it NOPE. no oil and coolant mixing trans fluid looks good no sign of a heater core leak.. have a few codes for sensor 2 knock sensor , evap canaster purge valve and a mass air peformance code.. im not worried about all that at this second just conserned with the coolant loss truck seems to have normal smoke in the mornings till it warms up and then nothing. is the only other option head gasket ? i was told these dont have a lower intake like in the older 5.7 were coolant passes threw. any help would be greatly appricated thanks
Castech Heads - http://www.gm-trucks.com/forums/index.php?...57746&st=25
thanks for the link just read threw the threads i am also having smiler problems "loud valve noise " periodically in the morning lasting almost 2 to 3 mins. havent pulled the covers but i can only assume the worse that i have the bad CASTECH heads .. so now i haft to look for heads most likely any poss places to get a decent set of heads i dont wanna get them from a junk years ill probably get heads with the same issue
http://www.gm-trucks.com/forums/index.php?...&hl=castech
I went through this in June. Gotta pull the rockers to tell for sure.
Mike
I got the bad heads .. I want to replace them as soon as possible. What should I look for for replacements? Foud a set of heads of a 2005 Yukon would these be ok or a set of a 2002 ? When was this problem corrected? Also if someone could give me a casting numbe for non castech heads I'd appreciate it or I was thinking of getting them from heads only .com any reviews I just don't want to get another set of bad ones and have this problem later on.. bone yeard wants 125 ec for the 05s and 175 for the reconditioned heads any more help would be awsome thanks
Ditto probably Castech heads..... Pull it apart and look for the logo... wavery, put a good link showing the heads..
Jbo
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
