Limited slip
Anybody out there have a new or almost new G80 for sale? Still looking for one for my 2000 Silverado. I dont do any offroading other than hauling firewood or deer during season. Any help would be appreciated. Thanks
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
