Truck Pics - Upper Michigan
redxemt
Haven't shared any pics yet, so figured this is a good chance. The first is looking South at the Mackinac Bridge and the second is near Pictured Rocks National Lakeshore.
Yooper or Just visiting?
Sometimes I wish, but just visiting! Home base is Ann Arbor for now.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
