rear end noise
tswiczko
2000 Silverado, 5.3L, 4x4, electric shift transfer case, auto transmission, g80 3.73 gear.
Over a year ago I replaced the differential, ring, and pinion gear, and pinion and carrier bearing, I had a great lay out pattern and .005 to .006 backlash when I set it up. I have put 16,782 miles on it.
about 3 months ago it started making a very faint growl, but would clear up in a few miles, and had no vibration. I put it up on jack stands and could not get it to make the noise so I drained it, no flakes or metal in the lube, removed the cover and done a visual inspection(all teeth present no abnormal wear) checked backlash still.005 to.006. closed it up and put fresh lube in it.
yesterday the growl came back only louder.
http://www.facebook....v=2624886430333 Tire on
http://www.facebook....pe=2&permPage=1Tire off
the gov lock still functions, the truck drives, and the noise goes away after about 3 miles
could this be an axle bearing or is there something more sinister going on?
Thanks guys.
O.K. I think I have the video figured out if someone could give it a try and let me know thanks
And Thanks a bunch for letting me know that my links were down Mark and GPSilverado if it weren't for you guys I would have never known.
WOW 50+ views and not even a hi welcome to the forum let alone any help with my problem
WOW,welcome i guess ,makin friends early i see lol
" WOW,welcome i guess ,makin friends early i see lol "
Yeah I have been known to speak my mind on occasion :lol:
Hey govtech, can you tell me if my links are working now? thanks
"WOW,welcome i guess ,makin friends early i see lol"
Yeah, I have been known to speak my mind at times :lol: Thanks for the Welcome
Govtech can you tell me if my links are working I was having trouble with them
internet wont help you here for that noise,ive never heard that in my life ,noises even with audio is hard ya know ,sry
loose the pumpkin and check the pinion and rotational drag (torque) of it
that noise goes away??????
i vote sinister
getting ready to do just that, in a day or two I just got a few things out of my storage unit that I will need.
yup after about 2-3 miles it quits hammering. I am thinking front pinion bearing, when the lube gets to it it shuts up.
but for the life of me I can't figure out a reason for when I take the driver side tire off it doesn't make the noise :shakehead: since The passenger side is still on it also tends to make me think it is something to do with the drivers side axle
Sinister is the only description that fits at this point
no way the pinion gets oil and shuts up,makes no sense
tear both rotors off a see ,maybe axle seal puckin on park brake shoes and chatteres up a storm,and after it heats up it stops ,
bet ya !!
    Gilkey96
    Gilkey96
  • Who's Online   5 Members, 0 Anonymous, 608 Guests (See full list)
