silverado badge application
If I were to order a set of Silverado badges for my '11, would I get a pile of separate letters or a single piece with the letters laid out and aligned, ready to be applied? in the event that I decide debadging is a bad idea, I'm just curious how much of a PITA it would be to get things back to stock...
I am not 100% sure but I believe they come with tape on the back and on the front. So you would remove the tape from the back, apply the badges then remove the from "alignment paper" that is used to keep the letters in order. I cant imagine them issuing them as single letters, I am 100% sure they do not put them on 1 by 1 on the assembly line.
LOL, I can only imagine. I went on a tour of the Fairfax, Kansas plant in 2000, back when it was being used to make Grand Prixs and Intrigues. I can't remember how they put the badges on back then...I wonder if it was automated.
  • 3 weeks later...
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,225 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
