2000 GMC Sierra wont idle
Ben_G94
I have a 2000 GMC Sierra Z71 and I have been having problems with my truck when trying to crank it. It would crank, but wouldnt stay cranked unless I was keeping my foot on the throttle. I replaced the fuel filter and fuel pump 2 weeks ago and I thought the problem was resolved, but it wasnt. It still does worse than what it did before, but whats wierd is that it only does this when the weather is cold (50-below). Can you help?
I'd make sure you don't have any codes. If not then I'm thinking injectors need cleaning. Might want to clean your MAF sensor just to play it safe.
I hooked it up to the computer and it didnt show any codes, so Ill try your next suggestion. Thanks for your help.
Could be several sensors, the coolant sensor tells the ECM what the temp is so that it knows how much enrichment to add for start up. I wouldnt start throwing money at it until you have a way to see what the sensors are seeing first.
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 552 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
