I noticed today that I have a hairline crack in my dash by the passenger airbag. Would this be covered under warranty?
2010 Sierra.
If you're not under warranty, send me a pm. I know a guy that has 2 new ones for a deal. I believe he has a black and a grey
Any chance you can get the information for me. My dash is cracked in the same location. Thanks!
Al
  • 10 months later...
  • 3 months later...
Search YouTube...guy documenting numerous cracks in the same spot as the OP and also on the drivers side. Not random cracks. Always the same spots each vehicle.
Strikes me as a design flaw.
After reading these posts......maybe I need one of those dash-rug things?
Do your vehicles spend most of there time out in the sun?
Mine is always out in the elements, however I do have very dark tint on my front and back and a limo tint strip as well, but I am not sure where this crack came from. I wish there is some way to fill it in or something!
my suggestion is to replace it ,,,because if you try and fix it with ,,,whatever,,you will NOT like the result ,you will always look at it ,,,
my 2 cents
my 2 cents
How much would a dash cost? Also who can I contact for a good deal?
Thanks!
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 437 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
