Fuel Gauge and other problems
I recently bought a 1999 Sierra z71 and each time I fill the tank, the gas gauge drops to empty and the slowly recovers. From things I have read this seems to be a fairly regular occurrence and is a symptom of the fuel sending unit going out. However, in addition to the gauge dropping to empty, I have also experienced what feels like a miss and a dimming of the instrument lights at the same time. If I shift into park, the lights become brighter and the engine miss becomes less. I have only filled up 3 times since buying the truck and 2 of the times the lights and miss have occurred.
I have a few questions-
1. What causes the sender to malfunction after filling up? Is the gas shorting something out or is the fact the float is high causing the problem.
2. Could the dimming light/miss be related?
3. If related, what is the mechanism at work that causes the dimming/miss and why does shifting into park help?
Thanks in advance for any help.
Jay
The gauge is an issue with sulfur build up on the sensor in the tank if i remember right. I had this issue once before and ran Techron Plus in the tank a couple times back to back and helped clear this up. But it must be Techron Plus since this is the only Techron that has the additive for the sulfur build up.
Hope this helps.
This happened on my 2005 Envoy XL, it is the fuel level sensor. They drop the tank and replace the sensor. I replaced mine in July to the tune if almost $500. Most of that was labor for dropping the fuel tank...BUT GMC sent a letter in Septemeber recognizing a problem with the sensor and offering to pay for 50% of the repair. I recvd a check 2 weeks ago from GM for $236
Thanks for the input guys. I was guessing I needed to be changing out the sender and fuel pump, but want to make sure that will take care of the problem. I had read about the sulfur issue, but have not been able to understand how that would cause a problem only after fill up. Maybe an internal short in the sender that causes the line to go directly to ground when the float is all the way up? If that happens, maybe that is what is causing the dimming of the lights?
JWH463,
Thanks for the info on the possibility of GM helping with the cost. Since mine is a 1999 and I am not the original owner, I am guessing I am on my own, but it is worth checking into.
Next question, What is the best source (ie quality unit but least amount of $$) for the fuel pump/sender ass'y? I have read the Delphi units are the best ones to buy, but am hoping for on line options that are better than my local dealer pricing.
Jay
jwh463,
Thanks for the link, it was an interesting read. Also, do you know who made the NAPA fuel pump?
Jay
The problem goes back prior to 99. Mid-90s GM SUVs/Trucks have had the fuel gauge issue. Fact of the matter is that the parts GM used are crap, and give out easily. Sulfur build up or other issues. I had the problem on my 99. Had the entire fuel sending unit replaced since my pump went bad also. That fixed the issue.
Try this: When the gauge is acting up, shift the truck in to neutral and see if it does anything with the fuel gauge.
Replace the entire sending unit in the tank. Pump and module that contains the gauge level floatie thingie. You will be glad you did. Most GM fuel pumps on the GMT-800s did not last more than 100,000 miles, if lucky. Typical wear and tear item.
Rockysierra,
The last time this happened, I shifted into Park and I believe the fuel gauge came up. This is one of the things that has me confused. Why would park or neutral cause everything to work correctly? I realize everything is now electric, but this particular symptom has me baffled. Since there is 83K on the truck I am planning on changing the pump/sender, but I always try to understand what is going on prior to changing things.
Jay
http://www.naioa.com/v2/modules.php?name=Forums&file=viewtopic&t=37605&highlight=fuel+level+fix
http://impalahq.naioa.com/HowTo/GasTankSender.html
heres information from an impala, but its the same process.
On the fuel level sensor switch there are little "teeth" that slide on a plate that transfers to your gauge. If the switch becomes loose or if the teeth do not touch the plate properly your gauge reads incorrectly.
hope this helps.
I had a 2000 Serria. My problem was the ground and wire pack off the sending unit.
A local garage repaired it in about 15 minutes (and $20.00), it worked till I sold it
Thanks Guys,
All good stuff, especially the pics in the links. I have a better understanding of the design and will be dropping the tank to check everything out after I get it down to ~1/4 tank. No reason to make it tougher than it needs to be.
Jay
Maybe I'm just missing something, but can somebody please explain to me the relation between the fuel gauge and an engine miss?
My motor has been missing a tiny bit lately, only when on constant throttle. I have had the entire motor gone over (its a new crate motor too) and replaced the plugs and wires. I have been thinking my problem is my fuel pump, and my fuel gauge acts a little weird. It fills fine, but the last 1/4 tank seems to disappear extremely fast. Could a pump and sending unit solve my problem?
Sorry to hijack the thread.. Thanks.
Here is an update on the problems I have been having. I have been driving my old '94 until it sells so I have not used up the gas in the '99 tank so I can drop it and replace the sender. However, yesterday I did drive the '99 and it stalled as I was pulling out of its parking place, It started back up but had the same miss I had experienced the last time I filled up, then stalled again and was completely dead. It finally turned over again and ran (still missing), and I drove it 100 yds to where I could pull over safely. I popped the hood and checked the battery cables and both were slightly loose. I tightened both cables and it fired right up and ran great. I am now wondering if the cables were loose, and that was the cause of the miss, and the miss is unrelated to the gauge issue. I still need to drive it more to see if the miss is gone for good, but so far no more electrical gremlins. I'll be driving it more over the next week and see what happens
DRT_RUNR,
The last 3 Chevy/GMC trucks I have owned all had gas gauges that dropped faster after hitting the halfway mark so I would bet yours is fine.
Jay
    • Pryme ! I was thinking of adding one to my 2024 6.6 gas  . Could you elaborate a bit more on your statement  Thank You
    • What a wonderful result! Great story telling to. You are quite multifaceted sir.  I'd keep it. Four is my limit too and yet we have five as well. One assigned the 'salt car' to do all those tasks you hate to ask of your 'Save for Good" crowd. 😉    Don't forget the antifreeze.    The Iron 4.3 is a favorite of mine.
    • Thanks Buck Wallace ! The more owners that tell me they are getting the same noise the more comfortable I will be with it !
    • Ancillary parts to the lower intake and connections went together without issue.   There was a brief pause when I leak-tested the fuel lines and injection system. Fuel was spraying all over. Lovely. O-rings weren't sealing the fuel lines to the spider, and inbound line was leaking at schrader valve, leaks at both flange nuts. It's moments like those when you just want to set fire to the whole shop, and be done with it. I was mostly enjoying the project up until that point, and was tracking to an agenda of having a running Blazer and a cold beverage in hand by dinnertime.    I found some larger Viton o-rings for my spider and some grease to get them to seat. One leak solved. Swapped fuel line Schrader core for old core. Still leaked. Swapped entire valve for old valve. Leak solved. Nudged the flange nuts a little tighter on the connections. Another leak solved. I could cycle the key / prime the pump and the intake was staying dry.    Reassembled the upper intake, with 10,000 vacuum lines, and filled the cooling system with water* (this is temporary, I'm not done with the cooling system yet).   Showtime!!   Cranked it over and smoke billowed, it was running rough. CEL illuminated and began flashing. P0300 and I somehow tripped a code for the TPS sensor, voltage low.    There's nothing as unrewarding as a vehicle that won't run (and produces the same code/problem) after hours of research and work.   Clearly I was in over my head. Was the timing off, did I stab the distributor incorrectly? Is the new distributor bad? With my limited OBD 1.5 data stream I really don't have a lot of parameters to see. The engine was pulling mad timing again (flooding?).   Think, Atlas, think.   1-6-5-4-3-2. One, six, five.....four, three, ....two. Wait a second. That makes no sense. 1 is the forward cylinder on the driver's side, so 2 should be the forward cylinder on the passenger side, not 6.    I can't believe it, but I'm looking right at it. Swapped 2 and 6 on the distributor and turned the key over, and...   It fired, coughed and stumbled, smoked, and then settled into a smooth idle. The scanner showed no codes, no lights on the dash, and the throttle was nice and responsive to gentle revs while it warmed up.   It's working!!! IT'S WORKING!!!   I paused for a late dinner, no cold beverage yet. I was determined to do my shakedown run. Did a basic safety and fluids check one more time and then went out and put almost 70 miles on it last night. She's a runner, runs good.   Came home and did a post-trip, post-mortem. The underside is dry *except* for where the last owner RTV'd the snow out of the intersection of the timing cover and oil pan. He said he had replaced the timing cover seal, but, my dude had clearly done it incorrectly and then tried to hold back fate with black RTV. Never works.   Yesterday morning I replaced the broken driver's door mirror. As much as I hate cheap Chinese parts, thank goodness for cheap Chinese parts. I think an entire new power mirror assembly cost me like $30, and it works perfectly. Replacement tail lights (faded, and one was busted) ran me about $12/side. I have a door pin kit ready to go in because the driver's door sags just a little and I want to fix that because there's nothing sadder than a saggy door.   I don't know what's next for this rig. Half of me wants to take some nice photos (there's a park nearby with a HUGE American Flag that always seems to be catching wind) and throw it up on CL/Marketplace for a couple grand and see if it flies. The other half of me... I've got a sweet running S10 Blazer that's been keeping my mind off of whatever I'm going through right now, and it's bringing some joy, and is cheaper than therapy. Maybe I'll keep it around for a little while. However, this is my 5th vehicle, just for me. 4 is really my limit, but they are not junk, so need very little attention. I don't know...there's a point where it's just too much and I don't see owning this truck long term. But I solved its major problem, got it running, so I'm going to stick a feather in my cap for now.   Sometimes we just need to get our hands dirty and fix something in the physical world to gain some satisfaction.
    • Happy 4th of July! Be safe out there tonight
