Multiple problems 98 Silverado
I have a 98 Silverado. We have rebuild the 5.7 vortec motor and the 4L60E transmission. Everything is stock in the motor except we went with flat top pistons and we had it bored out 30 over and has a new fuel injector spider. Transmission was upgraded with 3-4 clutch pack. Has rebuilt torque converter and new park/neutral switch.
TRANSMISSION: From the day we put the transmission in we have had problems. SES light came on instantly. Going into default gear but not all the time. Turn truck off and it is fine. Throwing the PO785 code. We have checked the ignition switch and have changed both the 1-2 solenoids and one of the 3-2 downshift solenoids. Waiting for the other to come in.
DASH LIGHTS: When I turn my headlights on my dash lights blow a fuse. Radio works fine as do my turn signals. Have replaced fuses and the headlight switch. Still doing it.
MOTOR: The motor has a loopy idle mostly while truck is in gear. Truck also surges under a load like climbing hills, etc. At start up sometimes dies or the RPMs drop then pick right back up. Also gets horrible gas mileage, like 12 miles to gallon compared to 18 before we rebuilt the motor.
Any answers to any or all of our problems would be great. Have spent a great deal of money on this truck to get it right and getting very frustrated that things are not working out.
Unplug the TPS sensor if it doesnt change how the motor idles then its bad,Could you IAC valve also when was the last time you did a complete tune disturbitor cap,wires,plugs,coil,ign module,Also wouldnt hurt to check or replace the fuel filter,and or fuel pressure.
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
    • Chris 21 I appreciate your constructive response. !!  😉😉😉   The 6.6 is gas.  Correct me if I’m wrong but by recalibrating the speedo you’re correcting the shift points of the transmission on these trucks.?.
    • That is a huge misconception.     Bigger does not always equal safer.  Modifying does not make it safer either, with exceptions.   Think of this.  Your truck in stock form is capable of emergency maneuvers, proper stopping distances, its handling is designed around the factory wheel/tire packages, etc.   37s and a lift?  Now you've affected your braking distances, handling and ride control.  You've raised your center of gravity higher.  Your front visibility is now obstructed more than stock, same for your rear.  Does it look cooler?  Yes.  Does it now work as good as it did from factory on road?  NO.       As for my mention of exceptions?  Say you had a sedan or crossover.  They typically come with all season tires.  If you swap out for a performance all season or a summer tire, you improve your car by lowering its stopping distance (better braking because of traction) and improve the handling (regular and emergency) of the vehicle.  That is an actually improving modification.  My old 2019 LD 1500, I ran UHP all season tires on 20in wheels in a factory offered size.  It improved all aspects of how it drove over the Duratracs it came with from the factory in the stock 18" tire.
