2011 Yukon Navigation in 2009
I just bought a 2009 Yukon Denali with factory nav, no USB. I am looking to upgrade to a factory nav with USB and from what I've read here the 2010 nav, part # 25966513, will work.
My question is, will the 2011 nav work in my 2009? It looks to be the exact same connections in the back, it's just a different part number: #22776895.
Thanks for the tips!
From what we know about it, you'll need the USB harness, the USB female plug and trim that goes in the center console, then you'll need to program it, which might be difficult depending on the dealership you choose to get involved with. Most won't program for any features that weren't there from the factory due to the limitations of the GM TIS, and that radio may only take programming as though it's in a 2011 vehicle. You should ask those questions and get good answers long before you consider throwing any money at it.
Hate to be a salesman here, but at over $1500 on EBay for this factory navi, it might be worth looking at the Advent, because it will outperform the factory unit in just about any way you try and measure it and cost you 30% less...
Thanks for the reply. I'm bidding on one, and if I can get it for under 700 or so, I should be able to sell my current one for minimal loss. Plus.... I really really really want to keep everything a factory looking as possible.
Just so you are aware Part# 22776895 is made for the vehicles with the rear DVD system.(RPO-UUK) Part Number 22776896 (RPO-UUL) is the same unit except that it is does not play DVD movies because it comes in trucks without the rear DVD system. Both have USB and are both designed to work with the Bose system. I'm not sure these 2 units will work in your truck if it doesn't have the Bose. Check Ebay, I got mine brand new (22776896) with a Nav Disc for $400.00. Just be patient and you'll find one.There is no need to pay an exorbidant price.
    ncleg
    ncleg
  • Who's Online   2 Members, 0 Anonymous, 1,229 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
