Daytime driving lamps
rubenoff
  • 1 month later...
a.
Respecting the eyes of oncoming motorists at night
there are some important things that we as driver's of automobile,s need to practice in order to respect the eye's of oncoming
driver's in nightime driving situations Fog lamps are supplied on many newer vehicles however these should not be used in clear weather and or nightime situations Because there is an increase of lighting being projected from the front of our vehicles towards the eyes of the other approaching driver,s Most vehicles now have the ability built in to the vehicle to allow operation of the fog lamps alone and the operation of rear vehicle tailamp.s and front park lamps, most common sense and properly written Motor Vehicle regulations will allow the use of fog lamps in place of the low beam lamps Because of lamps are normally being aimed lower so as to better peer under the fog, use of low and high beam is sometimes useless in foggy conditions because of the white light glowing backwards off the fog moisture particles into the eyes of the vehicle driver, amber colored fog lamps seem to work better because of less light spatter back into the eye,s of the driver using the fog lamps and the amber colored light is easier on the eyes of the oncoming drivers
The motor Vehicle regulations need to be re written to allow law enforcement to issue citaton's to drivers that drive around with fog lamps lit in clear weather or at nightime when the weather is clear.
Auxillary driving lamp's must be operated from the high beam light operation only so that the added light operates when the most seeing distance is required ahead of the vehicle at night, and to ensure that the auxillary driving lamps cannot be operated on Low beam operation to protect the eye's of the oncoming driver's
Frequent road side police Vehicle inspection's are required to catch and correct improper wiring and switching that allow the lights to be operated in a manner that decrease,s public safety and allows a disrespect to the eye's of the oncomimg driver's and allow a blinding headlamp situation that can create road rage and set up a head on collision accident waiting to occur
Some of the early Daytime Running lamp.s installed on vehicles allow the daytime running lamps to be lit in the daytime and then at the nightime they are called fog lamps and or Auxillary driving lamps and the operator has no means of shutting the lamps off
to respect the eyes of oncoming motorist's and or meet properly written and safe Motor Vehicle regulations that are supposed to be there for the protection of all drivers you and I
there is a great need to ensure that all vehicles have their headlamp alignment inspected in the following conditions
(1) when the unit is new fresh from the factory
(2) any time weight has been added to the vehicle ie. Canopy. winch, tool box, fuel tank, welder
or a deck that is used for carrying weight
(3) when the unit is used for towing trailers,
(4) anytime repairs are completed to the suspension of vehicle ( new springs etc. accident's)
(5) when the unit ages and there is settlement of the suspension ( 3-5 years)
as drivers we have the responsibility dim our lights when meeting oncoming vehicles, and when following vehicles to prevent our headlamps from blinding other's who share the roadway system
as a matter of common courtesy and to lower the risk's of creating creating head on collision accidents
so you sign up to a forum to bitch about bright lights at night? nobody told you to buy a little focus low to the ground. if you have an issue dont drive at night or tint your windshield, during the day i drive with my day time running lights on and my fog lights on, nobody is blinded by it by anymeans, do you try to block out the sun too? its pretty bright... dont drive if you have an issue seeing.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
    • The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer.
    • My 2026 Silv. 1500 WT (reg cab/short bed/4wd) has the 40/20/40 with storage in lower middle seat as well as the fold-down center bolster/armrest.   With the dual glove boxes this is about as much storage as possible in a std cab IMHO. Bill
