2003 1500 Silverado code O 5:O
My wifes 03 silverado 1500 with the 5.3 thru a code I have never seen and can not find any info on. it came up as O 5: O. the truck is running fine and has no problems. I have tried different scanners and theey all said the same thing. I cleared it and it has not come back yet. the light came on right after she started it and she shut it off and used my truck. the only thing thaat has been replaced is I put a new delphi fuel pump in about a month ago,also filter,and a year and a half ago i put on a new fuel pressure regulator. any help would be apreciated.thanks
