FS 08 GMC Sierra OEM 17" 6 Spoke Wheels
Ryan00TJ
I am selling a set of Four wheels off my 08 Gmc Sierra I purchased new. Wheels are OEM 6 spoke machined face silver design. 17X7.5", 31mm offset, 6X5.5" lug bolt pattern.
TPMS sensors have been removed but valve stem cores are still in all 4 wheels. I will include the factory black screw on lugnut covers not pictured here. Wheels have no curb rash, nicks or dents, only normal wear and tear for a daily driver with 30K miles.
One wheel has a few small marks on the face vs the others which are nearly perfect. All wheels have the wear marks where the factory wheels weights were placed on the outer lip.
I will send additional pics available on request.
I am asking $275 plus actual UPS Ground shipping charges.
THIS SET OF WHEELS WILL FIT YOUR
00-10 YUKON, YUKON XL, YUKON DENALI, SUBURBAN
99-10 SIERRA 1500, SILVERADO 1500
88-98 SIERRA/SILVERADO 1500 4wd ONLY
89-99 YUKON/SUBURBAN 1500 4wd ONLY
ONLY THE 4wd UNITS WERE SIX LUG DURING THOSE TIME PERIODS.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
