2006 suburban rims and tire packages.
fbodydukie
I want to get a set of rims and tires for my 2006 suburban 4 x 4 and came along this set.
will they fit my truck without problems?
They are 17" rims 6 bolt (the same as the truck has now) steel with chrome cladding, circle holes all around the hub.
Mounted with 265 70 17 winter tires.
I don't know where else to ask.
Thanks
Its a GM wheel going on a GM truck, so no aftermarket potential issues. Police tahoes leave the factory with that wheel on so if you want them grab them.
If you have 17" with 265/70/17 on there now then there is no issues. The only things that comes to mind are to make sure you have lug nuts with the external threads on them to put the center caps on, and ifyour Suburban has Tire Pressure Monitoring then you would need sensors if you wanted the light off but thats about it. Will bolt right on.
