2002 Yukon XL ABS Fuse
Westend99
Left for work yesterday am and my abs light came on. Got to work at 7:30, returned to my car and there was absolutely NO power in the car. I couldn't even get the door remote to work. We jumped the car and it has run fine last night and today. Any suggestions? Absfixer.com recommends pulling the fuse so the battery doesn't drain. Could the fuse be blown? Any help would be great. Thank you!
lifes question for me is why do people call a truck a car in the states ?? oh well ,no answer will come to me tonight so ill answer this question instead lol
what that web site means is the EBCM is drawing to much with the key out and they want you to remove the fuse to prevent that from happening and as a diagnostic for you to see if it helps
if the fuse is open ,then its like its pulled ,so your thoughts are backwards ,,
just take it to a garage and have them scan it and give you an estimate to fix it ,,i think you MAY be a novice and will not be fixing this yourself and i hope you wont either
dont be offended ,its not intended at all
Better off taking it in and having codes checked when the light is on. You will most likely save yourself some headaches by having it done by the pros.
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 623 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
