File path not found. OGM-1 how to
I installed the OGM-1 today and ran into the "file path not found" when testing the NAV. Simple fix for any that have this problem in the future.
1. Make sure SD card is in all the way and browse the exe file.
If the does not work follow these steps:
1. Take SD card out (with unit powered off)
2. Turn on unit, select NAV. Once you select NAV browse the exe file and select this file.
Hope this helps the new OGM-1 users in the future.
the Advent OGM-1 Nav unit everyone has been buying recently. I received mine yesterday, everything is flawless and working perfectly
