psi for 35" mud terrains
redkaz04
hey guys,
I searched, but no luck. What PSI are you guys with lifted trucks running in your 35s for the highway? (truck unloaded) Thanks!
Dealer put 48psi in my nitto trail grapplers (35x12.5R20) I think it is a bit much??
could be, could not be.
an easy test is to get some chalk and draw a line across the tread with it from sidewall to sidewall. drive around the block. if all the chalk on the tread is gone your tires are properly inflated. if the center of the tread is still there theyre too low, if only the center is gone theyre overinflated.
i run a little over 40 on mine- mine are 34s. running 36 psi like the door jam says just doesnt look right- they look flat when only filled that much.
    BigJake
    BigJake
  • Who's Online   4 Members, 0 Anonymous, 561 Guests (See full list)
