keyless fob issues & aftermarket bulldog
Hello howre y'all today?
2000 chevy silverado 1500 ext cab, 4.8L V8, standard transmission.
I was wondering if anyone ever solved the problem where the truck enters keyless remote programming mode but doesn't register the remote and won't exit the program properly. The new remote is the right one, all #s same as the old one, battery good, signal good.
If this is a pcm problem, would an aftermarket bulldog kit work? And would it work with my standard? I wonder because I can't crank it unless the clutch and brake are pressed, if not the truck just honks.
