Parking Brake doesnt work..
07sierra8.1
Iv got a 2007 GMC Sierra 2500HD Classic w/ 8.1L. Disc brakes all around, I recently replaced both rear rotors, Parking brake shoes, new calipers, pads, hardware, and brackets (those were for an unrelated reason) but i got everything back together and adjusted the parking brake shoes to where they just slightly drag on the parking brake drum inside the rotor as my chilton manual says...but the parking brake will not hold the truck on an incline still. When pressing the parking brake lever down it only goes down about half way and stops like the shoes had come out and made good contact with the drum but it wont hold the truck.
Make sure the drum/shoes are good and clean - i.e. no gear oil or grease. Scuffing the drum/shoes with sandpaper helps too. Blast them both with brake cleaner & wipe down good with a clean rag or paper towel. If that doesn't work, try reversing them if possible (top to bottom).
It's a stupid design. I still can't figure out why GM went with rear disc on these. You need a drum for the parking brake .... so why not leave the whole damn setup drum??? There's a reason why every tractor trailer, dump truck, etc. on the road uses drums front & rear - they work ... and they handle the load. Glad my '07 has them back again.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
