Hello and Confused
tereptile
Hi all, I am new to this forum and need some help. My 4,3 2000 sierra will not start after sitting without a few drops of gass or starting fluid in the throtle body. I have change the oxygen sensors up stream, temp coolant sensor, ignition control modular, took off intake manifold and rebuilt the spider injectors with all new O rings, rebuilt the fuel pressure regulator, the in line fuel fiter has been change about 8 months ago, and a tune up with wires cap and rotor same time as fuel filter. I can clearly hear the pump running when i turn the key to the on position.
Thanks in advance for an help
David
You need to know what the fuel pressure is. Without that it's a shot in the dark.
put on the gauge and turn the key,
whats does how hot the engine have to do with fuel pressure?
stop throwin parts at the truck,,,all that could have paid for a diagnoses
Well if he knew the answer to that question then he wouldnt have ask it ! Just because your a tech, I guess, doesnt mean he is.
    blueskytruc
    blueskytruc
  • Who's Online   1 Member, 0 Anonymous, 532 Guests (See full list)
