changed wires and plugs
i changed my spark wires and plugs in my blazer.it still chugs.i took the nice plugs out of my 95 z71 .the plug part number for my blazer is 26 but the number for my z71 are 25.the distributor cap has kind of a ticking noise in it i didnt replace that anyone have any experience with balzers?
if you have new plugs and wires, put a cap and rotor on it. check your timing also. i dont know the difference between the plugs you stated, i just go to the parts store and buy which ever ac delco plugs it calls for. now if it were a small engine plug, i could probably throw you a part number :ninja:
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
