New tires and rims ordered
bdseagles93
got some bad news....waited close to a week for them to come in and the tire shop went to go install the rims this morning and they noticed a crack on one of the rims. So i have to wait another 3 or 4 days for a replacement! This is torture!
there is one positive thing. ive been waiting close to 2 months to get my dual exhuast done and the guy finally called and is doing it friday. so i guess my truck should be looking pretty scwheet by this weekend
okay im officially pissed off. The replacement rim came in today....opened it up and it is scratched to shit. SO itll be the middle of next week before the new one comes in! :banghead:
Man that sucks...... I would tell them they can overnight my wheel, and give 50% on labor or I'm going down the street :smash:
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
