Hey SUV guys...
HillHound
Man hes got some good replies to his hatemail lol. Hmmm methinks I should borrow one of my fathers big rigs this week and drive around in it for the image? :jester:
They are all G.A.L.Y.'s  (God Awful Land Yachts!!)  The Excusrion was my least favorite.  And what really pissed me off was the person usually driving it was a middle-aged woman who could barely see over the dash.
Varmint,
Only bad thing about putting soccer moms in those tanks is they would have to learn to spilt shift!  Either that or put an Eaton Auto-Shift in the truck....
That would be interesting if someone took a Kewnorth T2 or a Pete 387 and put a van body on it!  Then adorn the beast with an N14 or a Cat C-16!!!  Then you would have yourself the ultimate personell carrier!   :jester:
Saw somthing almost like that in real life at Talladega Superspeedway back in 97. Guy had what appeared to be a KW with the sleeper extened all the way back to where the 5th wheel would've been. And it was all cab too. As the son of farmer who owns 5 big rigs, I begged the question of why would somone do this, specially if they arent going to use the rig for its intended purposes.
Alot of people do things just because they can do it. And I bet that's probably why he did it.
