iPhone/iPod Video on OGM-1
I hooked up my iPhone4 to my OGM-1 with a Jensen JLINK-USB cable (connected to the Media Link) so I could check out the video. I can locate the videos on the iPhone from the OGM-1 iPod/iPhone screen, but when I select a video to play, I get the sound but no video. The Setup screen and the Picture Adjustment screen both appear when I touch the screen, there's just no picture.
Is there something I'm doing wrong?
Push the round plug into the media hub hard- I had the same issue and it turned out the barrel plug was not pushed in all the way. It was very firm the first time I tired it.
I tried pushing the barrel plug in, but no joy. When the plug is in all the way, I can adjust the brightness on the screen, but there's no picture.
I've had some issues with the Media Link connector at the back of the OGM-1 (no XM left channel, intermittent iPod connection, etc) After pulling the unit out a couple of times and adjusting the cable routing, everything's been working great for a couple of weeks. Now that I have a JLINK cable, I guess I'll pull the OGM-1 out again so I can test everything.
Thanks for your reply.
I posted this four days ago - give it a try and please report if it helps:
Posted 17 March 2012 - 10:17 AM
About 10 - 14 days ago Apple released it's latest update bringing their operating system (ios) to version 5.1.
We have tested all devices and products in the Advent line and we are fully compatible with this update.
We have had several calls complaining that after the Update was done on the iPhones they would not play video.
Apple suggests a hard reboot of the Phone if you have this issue. After rebooting the phone the system restarts and corrects this issue in the phone.
For more information on how to hard reboot an Apple device or details on this please see Apples Support Website.
Well, the hard reboot of the iPhone did the trick. Video is working!
And the sad part is, I had read your post about rebooting the phone the day you posted it...<sigh>
Thanks, Walt!!!
Thanks, Walt!!!
:thumbs:
