Remove/replace vent valve solenoid on 03' 5.3L extend cab
Is there a trick to get this sucker out of the tight spot it's in? It looks like one connection in the front, and I felt one clip on the top/back that I popped off, but can't figure how to get it out. Do I need to remove the bracket bolt or should I be able to pry/slide it out?
From all the research I've done it sounds like the replacement with be mounted outside this area?
Any help would be greatly appreciated,
Ben
