sub question
anyone install a subwoofer in the lower console section of their extended cab silverado? If so any pics of your install and how did you do it? Or any other places that make it a stealth install (and i do not want to go under my rear seat because it is open in the UP position and the box would be in my way) Im trying to think of the best place to install a 10" subwoofer to add a little bass to my new system and this is the only spot i can think to make it a stealth install.
The problem with this is that the bass won't sound that great with the sub located so close to you.
Save some money and get a stealth box from JL Audio. I know they're expensive, but it would make for the cleanest install.
Cheers, Brendan
