Wheel trade
Anyone interested in swapping their 18" or 20" stock or aftermarket wheels (with stock backspacing) with 35s for my Akuza 359 20" with toyo open country m/t's.
I put a RCX 7.5 lift on my truck and my fronts stick out too far.
Located in NE Arkansas
Txt 8703620554 for pics...
Best have for now...
33 20 12.5
Wynne, Ar
Not sure what exact offset is but they stick out about 2"s further than stock
Wheels are 20x10
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
