Spring Cleaning
here are the taillights you wanted to see. They're from a 2001 Silverado but will fit any silverado from late 1999 to 2005. They're in great shape and would make an awesome set to tint as well.
  • Replies 34
Oo that's not the silverado tails I was looking for. I want the 03+ Chevy tails. They fit 99-07 gms so I thought that's what ya ment
Sent from my toilet-ed HTC Rezound
  • 3 months later...
Do you still have this available (with all the brackets and mounting clips)?
Overhead console (smaller one with dome lights/cubby hole in tan for 99-06 silverado/gmc) $10shipped
