Remove road paint from tires
I was momentarily stopped in a left turn lane in Twin Falls, Idaho when a road painting crew passed the line of turning vehicles on our right side in the through lane. Not thinking anything of it (I stupidly assumed, because road painting often takes place while other traffic is around, that the sprayed paint would be restricted/directed to the roadway lines), I continued on my trip (pulling a travel trailer on vacation). The day was hotter than Hades with absolutely no breeze.
At my next stop, hundreds of miles farther down the highway, while gassing up, I found all four tires on the passenger side had been dusted with white paint. As I was travelling and restricted to a schedule, I could not do a cleaning for another two days. However, when I did try to hand wash the tires, the paint would not come off.
Can anyone provide the name of a good product that will take road paint off tires without being too aggressive on the rubber??
Paint Thinner. :thumbs:
if they were permanent epoxy resin pavement markings i dont know if its that easy, otherwise thats what we would use when they need to be removed from the pavement. they need to be grinded out of the pavement for them to be removed. it might be different being laid on rubber though.
Paint thinner was one of the first things that popped into my head, but I was unsure, as BigBlueSilvy notes, if conventional methods would apply as that type of paint is designed to withstand heavy traffic and all kinds of heat and weather. I was also not sure if thinner would have any adverse effect on tire rubber. I will give it a try on a small area and see how it works.
The thing that p****s me off the most is the trailer is not even two years old and the Sierra is less than four months old.......
Thanks for the comments.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,231 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
