265/60R20 on a 1500....
mc7719
Soooo I have found a set of tires, new take-offs, for cheap.. however the size on them is 265/60R20 (off a 2012 Silverado 2500). Now I have looked around... and its a REAL odd size.. like there's not that many manufacturers out there.. but I checked, and it IS the factory tire size.
Anyway, calculating the measurements compared to my stock 275/55/20's....
Tire width: 10.82in. vs. 10.43in. on the new
Overall diameter: 31.9in. vs 32.5in on the new
Rim widths on both are 7.5-9.5in.
So... with the less width, and slightly more height.. technically, they shouldn't rub?
Plus they are an LT tire, load range E, and not a P tire like my 275's. That being said, they run at a higher PSI (About 50-55) so will that send my TPMS into an error?
I think they'll fit, but you may need to trim just a little plastic because of the extra height. You could always throw on a leveling kit and then you'd be fine for sure. As far as your TPMS, you'll need to get the 'magic number' reprogrammed for somewhere like 45-50 psi....because right now it's looking for 30 psi to make it happy. It will think you're running too much pressure when you get your new tires. When I switch to Load range E tires on my truck, I had it reset to look for 45 psi....that way I could run 40-45 psi all the time...and bump to 50-55 psi when towing....and the TPMS didn't have a fit.
Who can reset the TPMS to recognize a higher pressure in the tires? I have an autocal and may need to reprogram mine when I switch to the the Cooper ATP or Zeon 275/60/20 since they will need a little more pressure than 30.
The dealer def can. Pretty much any reputable tire chain there should have the tools to reset it. At least here they do.
