It's not a minivan ill use my back seat for whatever I want
Sent from your truck via Tapatalk
Is the box even fastened down at all?
Edited by Frogfish
I can't have a large system just sitting in the back seat as so, I have my two ten's behind the rear seat so its functional and people can still use the rear seat. As for the kenwood's, I only trust their amplifiers since they make quality sound system receiver's , which is why I bought an 1800 watt mono Kenwood amp for my shallow mount Kicker CVT's which hit hard in the sealed box. Do you plan on getting you an aftermarket head unit soon?
Edited by Carder
I've been running those keywords for 5 years no problem that amp is the same one u mentioned I love it as far as a new hu I'd like a pioneer touchscreen but there's other things on the list before that
Like this?
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
I should have banned you for the drunk texts
Like this?
Is that a avh x5500bhs? That's what I'm thinking about getting.
Sent from my DROID RAZR using Tapatalk 2
AVH-P4400BH
Edited by chawkins6789
Drove about 6 hours today. Tulsa was fun, but I'm glad I don't live there.
Don't trust crapple maps there either. Mine took us to a refinery in the ghetto and told us it was a casino.
LOL, google maps did something like that to me a couple years ago. I relied on the map instead of signs
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,012 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
