Hello everyone, I was reading this the other day and I also had an issue with my TPMS light staying on. Each sensor was reading accurately, however the light stayed on. I wasn't getting a low pressure warning or anything. I finally replaced the sensors and still had the same issue. Took it to my local stealership and hours later they came up with a solution, the module that reads the TPMS somehow got set to read my tires at 60psi and not the recommended 35psi, all they had to do was reprogram the module. Hopefully this helps...
  • 5 months later...
Not sure if anyone is still monitoring this topic, but it seems that I am in a similar situation. I have not had any tire work done in over a year when I had all 4 replaced, but the sensor for one of my front tires started warning me about 7 days ago. The actual pressure in my tire is around 37 PSI but the sensor says that it is only 25 PSI. My tires are rated for 44 PSI. Really don't want to go to the dealer because my 2011 Silverado is far removed from warranty.
Any other options to fix this thing?
  • 4 years later...
Here is what I ran into with my 04 suburban. I chased that light for a year, New everything.
What I found was the dimmer switch was causing a short through the instrument panel. Confusing the body control module and keeping the tmps light on.
I took the light switch out, took it apart cleaned all the old grease and grimeout of headlight switch as well as the dimmer switch. Put it back together with a some new dielectric grease it. I put the same dimmer switch back in. Hit the key and the light went out after the start up bulb test and no more service tire monitor.
I know that this sounds unreal and why would the dimmer switch effect the tmps? I asked the same questions. I found the dimmer switch code using my tmps scanner programmer. Thought oh great new problem. Fixed that pro lem and it fixes my tmps system. Good luck to all.
  • 4 months later...
We'll be dealing with the same issue on my friend's new Suburban project. The previous owner did a few lights mod on it including the dash lights, dim, and headlights. The TMPS light lit intermittently after. We'll check the wiring and connection when it returns from the shop for the installation of the brake pads and nitto tires, plus the alignment.
    B07
    B07
  • Who's Online   1 Member, 1 Anonymous, 871 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
