Removing passenger airbag switch
I'm looking into getting a cubby cam backup cam system for my truck. The camera is in the tailgate bezel and the screen is located where the switch that I need to use my key to then the passenger airbag on and off. Will removing the switch cause problems?
Birthdays coming up and that's on the list. Ill try to post pics of the system
Sent from my DROID X2 using Xparent Red Tapatalk 2
Yes, unplugging it will set a trouble code, turn on the light and disable the airbags.
just relocate it into the glove box thats what most do... disconnect the battery(ies) and wait a couple minutes to completely power down, unplug the switch move it over then plug it back up
How does the crew cab models operate without the switch then?
Same system, but different wiring on a crew cab that doesnt contain the provisions for the switch. You need this switch, tuck it away your glovebox, I did this on my 01 a few years back.
Does the small switch area separate from the rest of that square where the quadrasteer button would be if equipped
Crew cabs never needed it. The switch is there for people who might have to put a baby seat in the front (ie reg cab or in some instances the ex cab too). So since the crew has a bigger back seat, the switch is not part of the system.
    mighty K20
    mighty K20
  • Who's Online   3 Members, 1 Anonymous, 621 Guests (See full list)
