gear lever problem: 2009 GMC 2500
hey there,
well just right now, its 3 am and i just got back from a service call, and right before i got home a few streets away i had to pop it into manual mode and downshift myself, and slammed on the brakes, because some idiot ran a red, so i had to slow down pretty fast and that was my reaction(tow haul was off)...now once i had slowed down and turned onto my street i tried popping it back into drive. but nothing, the gear lever was loose, and once i stopped it would go up and down through all the positions but between Drive, Manual mode, and 1 its loose, and feels loose. i had to reverse into my driveway and i got stranded in the middle of the road...with a 5000lb trailer...so i unhooked my trailer and pulled it up with my V (dont even ask how i hooked it up to my V it was a work of art...and once that was in its place, pulled out my winch and pulled the truck up to where i usually park it...at this time, when you move the level up and down, it wont shift into anything besides Manual mode...its basically stuck in manual mode. but the lever moves enough for me to take off my key, in park position and neutral...
its weird, i dont get it, is it an electrical problem? or is it the lever itself....i mean it popped into park or neutral for me to take off my key from the ignition...but it did not go into park because it was rolling down the driveway without the e brake... any insight or idea would be highly appreciated as i gotta be at another service call on monday, and cant do it without my truck...and definitely cant afford a setback like this...
thank you in advance
I.R.E.
tmrw morning after a nice rest ill crawl under the rig and have a look at the tranny cable see if that snapped...or broke somehow, but besides that any ideas? please and thank you...
Yeah, it was the tranny cable by the transmission, such a cheap locking design...i stopped by the dealer to have a look at the replacement transmission cable and saw the piece that was missing on mine, and didnt give me much confidence, so i cut off the pin on the existing arm on the transmission, drilled a hole through the original pin location and ran a 1/4" threaded rod, with nuts, washers and a locking pin. and it works just fine, now i dont have to worry about the cable coming off when i really need the truck.
thank you, and sorry for posting this tread twice, didnt know where it would be more appropriate.
have a nice weekend all, im off to the track
    Greg3160
    Greg3160
  • Who's Online   4 Members, 0 Anonymous, 870 Guests (See full list)
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
