2007 5.3 Engine Help Needed
kdog57033
Hi all. Newbie (long time lurker) here. Love the site and all the info you guys provide!
Got a head scratcher here (at least for me). I have a 2007 Sierra with the 5.3 (VIN M) and 150,000 on it (lot of over the road driving). Was driving it home a few weeks ago and heard a pop and it shut down. It cranked over but could hear air popping back thru the intake, so I assumed a broken timing chain.
Just got around to working on it and found that the chain was not broke, but had jumped 2 cogs. It appears that the plastic guide piece on the tensioner (drivers side) broke off and went between the gear and chain causing it to jump. I just put in a new chain, gears, and tensioner and set the timing. Got it all back together and it will not start.
I have about 150 lbs comp on #1, but zero on #3 cyl. Pulled the valve cover off and it appears that the rockers/valves are moving full travel on all cylinders. It got late and I was getting frustrated, so I bagged it for the night. Gonna get back at it, but wanted to check here before I go back out and bang my head against a wall again!!
Any ideas? I didn't think these were interference engines, but am I wrong and could I have a hole in the piston?
Thanks for any advice you might have!
Thanks Gov. That's what I was figuring. Just thought I would ask before tearing into it anymore. After reading your post, I did put air to the cylinder and it is leaking past the intake valve. Guess the dealership mech that I asked and told me that it was NOT an interference engine needs to go back to school.... :fume:
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
