Average fuel economy indicator...
I have a 2007 Sierra 2500HD Classic w/ 8.1L....
When I got the truck 2 years ago, the avg. fuel economy reading says 10.3 MPG....Hasnt ever changed or read anything different since. I know the computer can tell its getting better fuel economy because the "Range" milage changes significantly between city and highway driving...
Does anyone else have this or is it normal? Its not really an important thing to me, I am just curious, why put a feature in that isnt accurate 9 times out of 10 right?
I think range is based on current mpg, at least thats how it works on my bike. I dont reset mine and let it build a bigger chuck of data so its closer to being right. Tho if i bought it used i would reset it so it learns my driving habits
Sent from my ADR6400L using Tapatalk 2
Yeah when I bought my truck used, it read 14.7L/100kms. Reset it and its pretty much set on 12.7L/100km for me. I do more highway then the previous owner I believe.
Oh I had no idea it was possible to reset....I just reset it, and wow...it actually works and fluxuates as I drive!!! I guess I coulda found this out if my truck actually came with a owners manual :throwup: . Thanks for all the responses...It wasnt really an important issue...just being curious sometimes teaches you something new. :ughdance:
gm has a app u just scan your vin and it pulls up the manual
    bellssn690
    bellssn690
  • Who's Online   6 Members, 0 Anonymous, 579 Guests (See full list)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
