I have a transmission question regarding a 1996 K-1500 potential purchase. I know normally a 1500 would have a 4L60E, but the truck I'm looking at has the 6.5 turbo diesel. Would this still have the 4L60E, or will it have a 4L80E? The truck is over 100 miles away, so not easy to organise a trip to have a look.
Thanks in advance!
can have either ,why ? whats the problem ?
should have an 80 behind it though ....
square pan is a 60
Thanks for the reply. Its a truck I am considering buying... I'm not a huge fan of the 4L60E. Much prefer the 4L80E for a slushbox. Normally I would get a manual, however, the pickings are few here in the U.K.
square pan is a 60
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
