Definately not your average Kias...
pacodiablo
Usually when we think of a Kia we think of small econoboxes that we would never want to own.  It turns out that Kia actually produces some pretty serious trucks...if you don't believe me, click HERE.
Take this Kia KM450 1 1/4 ton, add the 10 year / 100,000 mile warranty and you have one bad ass truck...
Is that any match for the bunny though ???
I thought the bunny ate Kias  :eek:
One of my buddies, the Jeep truck nut, is building a 68’ Military Kaiser Jeep M715 with a TBI 350, 700R4 and NP241 tcase pirated out of a 91’ Suburban.  The two tcases will yield a home grown 4 to 1 low range tcase when it is all done.  Should be pretty cool.
He mentioned something about a Korean auto manufacturer building the M715 on a borrowed patent.  I am not sure who actually owns the Kaiser M715 patent….AM General or DaimlerChrysler.  Either way the Koreans have made it much easier for him to find parts to rebuild his rig and some of the money for each Korean M715 knock off comes back here to the states
Thanks for the info paco…just when I though you never had anything of value to share with the class you dug this up.  :fume:
Just messin with you man.  :eek:
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
