Triple Turbo Cummins
TxDoc
http://forums.atsdiesel.com/showthread.php...amp;threadid=30
We have decided to give a look at a very high HP truck in progress. It is a 12 valve with two port twins on top with HX60W signature 600 on the bottom. Custom ground cam, low compression pistons, ported & o-ring head & more & more. The engine was lowered to 23? centerline to crank. This engine was also moved back 4? to the firewall. The suspension is four-link air in back & lowered in the front with air bags. We will not give out too much more at this point however this is just the start to what?s coming out this race season. The transmission is a 47RE with custom-built electronics. This should be good race season.
Pics below--could not link to them, so.....
http://forums.atsdiesel.com/attachm....tid=127
http://forums.atsdiesel.com/attachm....tid=128
http://forums.atsdiesel.com/attachm....tid=129
http://forums.atsdiesel.com/attachm....tid=130
http://forums.atsdiesel.com/attachm....tid=131
http://forums.atsdiesel.com/attachm....tid=133
http://forums.atsdiesel.com/attachm....tid=134
http://forums.atsdiesel.com/attachm....tid=135
Thanks  arveetek
